First post, by zxSpectrum
hello,
Is it possible to rezise the dosBOx window, but not to the fullscreen, just a little bigger than it is... i want to play swos whit this, but its a small window, and i prefer to play games in windows than in the fullscreen mode...
thanks...
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well look at the readme
there are multiple ways of doing it.
the most simple one
set output=overlay
and hwscale=2.5
Water flows down the stream
Reply 3 of 4, by Guest
just one more thing, ..it first time i use this aplication , so don´t strange this questions....
is there a way to make the other window to don´t appear, there are 2 DOs windows that appear, right? ...i want to get rid of the other one where the game don´t appear... i see that there is a command -noconsole, ..is this command for that?..to just appear one window?..if so how can i use this command...
and can the main window be rezise not following their natural proportions,..for example, ..just rezising for down...and not resizing the sides..
thanks...hope you guys understant ..english is not my language...
Reply 4 of 4, by Ja7482
Yes, the -noconsole command is the command that will give you 1 window instead of two. The way I have my dosbox setup is I have a shortcut on my desktop where I include the -noconsole command. All you do is go to the dosbox folder, right-click on dosbox, then select "send to desktop" which should create the shortcut on the desktop for you. Then right-click on the dosbox shortcut and add -noconsole at the end of the target line.
