Small bug...
First post, by ComputerPsi
Hello. Well, the program works, very well, but when testing it, I found that it had an error, when running DOS.
This is the Dos I use - http://www.freewebs.com/venia/command.com
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
why use dos in dosbox? dosbox comes with it's own dos
no need to start another command.com
that's the command.com looks like msdos 5
Water flows down the stream
