First post, by Guest
Is there anyway you can get VDMsound to work with Dosbox? Whenever I run the dosdrv form within dosbox, it closes dosbox.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you can't and you don't need to.
dosbox comes with it's own soundblaster emulation.
Water flows down the stream
Reply 3 of 3, by `Moe`
Dosbox is not a simple DOS box, it doesn't run natively as the Windows DOS box does. Dosbox emulates everything, the CPU, sound, graphics. Which is why it is a lot slower, but runs much more games. What you are seeing (hearing) is most probably simply wrong settings: Cycles set too high, not using dynamic core, or simply a too slow PC. Search for the various guides on how to optimize your config, then you'll get clear and great sound.
