First post, by FED1943
First,I want to thank and congratulate again all Dosbox team,go on,boys,great work.
Next,I want to apologie if this is not the right place and,mostly,by the childish nature of the question;but that is what I need and understand.
Yesterday,in .62 default Config file questions,Moe wrote:
start up dosbox and use the command config -writeconf dosbox.conf .
I did it and it was generated a shortcut in the desktop,seeming to be a perfect copy of the configfile of the installed dosbox program.
So,there are now four boxes:the said installed configfile,the two boxes opened when the dosbox is running (the one who will contain the game and the one where the CPU cycles are noted) and the shortcut;where must I edit the alterations to the config ?and must I do something more?
Thanks for your help.
Best regards,
