First post, by KushanFarsight
hi, i wondered if this would be at all possible on the new range of smartphones (Smartphone Windows Mobile 2003) it uses a lot of the XP system setup and so would it be possible to modify a dosbox version to run?
Thanks
Farsight
Reply 1 of 3, by DosFreak
Haven't really kept up with the smartphones but aren't the average speeds like: 133Mhz, 200, 324Mhz, 400, 624Mhz. With usually around 32mb-64mb of RAM?
Not sure what performance would be like for Dos games on an ARM/RISC architecure on a smartphone of less than 600mhz. Probably not too good
Make your games work offline
