First post, by Guest
hi
i've just installed dosbox to play x-com, but i cannot manage to mount a drive ...
for example i try to mount my cdrom (same with folders/hdds) with:
[z:\mount D "M:\" -t cdrom -label XCOM]
and dosbox returns
[MSCDEX installed. | Drive D is mounted as CDRom]
but when i enter
[z:\cd D:] or [z:\cd D:\]
nothing happens - the programm just returns to [z:\]...?
thanx for hints
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
been long since you used dos i presume ?
any way the correct command is
d:
Water flows down the stream
