First post, by jusid
Modem support is broken in 0.62.
0.61 works fine.
Reply 3 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
We need details.
For example in which program are you trying to use the modem?
Do you use a correct DOSBOX.CONF? (from 0.62, not from some old version of DOSBOX).
Mirek
Reply 4 of 4, by jusid
I used fresh install of DOSBox 0.62. Then I enabled modem in dosbox.conf by setting modem=true
First I tried to use modem in Retaliator. No success.
Then I tried communication program BCOM. It does not found modem. There is no OK response to AT commands.
I decided to try 0.61 version. The modem works in 0.61.
