First post, by CMDLineKing
I have been ripping my old dos games down to launch on DOSBox, but I kept running into issues with Redbook CD Audio. I used several different programs to Clone the discs in various formats, but even discs without protections would run into weird errors after mounting. I could copy the contents down and create a generic ISO and the issues went away, but of course I lost CD Audio, due to ISO's being unable to have audio tracks.
I did some digging around after reading about the BIN/CUE format and stumbled across some things that indicated that the CUE sheet itself could be modified, and include external files to make up tracks.. WHAT? Really? So, keep poking and find that you can mount an ISO with a CUE sheet.. So I attempted to rip down my audio to MP3 and use this in the CUE sheet (according to one website this would work), but no dice. So I pulled it all down as a WAV and combined that with my ISO File and IT WORKED. So now, I have Warcraft II Beyond the Dark Portal working with CD Audio, but a self compiled ISO in MODE1/2048. BIN format was MODE1/2352.
I used this same method to create CUE Files for some other games that were having issues with CD Audio and it fixed them all! Before, if I did get the BIN/CUE format to work I would get audio stutters or pops during game play, but with the ISO+WAV+CUE solution I just get smooth game play!
CUE Sheet Contents:
FILE "WARCRAFT2_EXPANSION.ISO" BINARYTRACK 01 MODE1/2048INDEX 01 00:00:00FILE "WARCRAFT2_EXPANSION.WAV" WAVETRACK 02 AUDIOINDEX 01 00:00:00TRACK 03 AUDIOINDEX 01 00:06:02TRACK 04 AUDIOINDEX 01 06:36:61TRACK 05 AUDIOINDEX 01 13:48:48TRACK 06 AUDIOINDEX 01 17:30:54TRACK 07 AUDIOINDEX 01 21:07:07TRACK 08 AUDIOINDEX 01 22:05:10TRACK 09 AUDIOINDEX 01 22:42:71TRACK 10 AUDIOINDEX 01 23:40:25TRACK 11 AUDIOINDEX 01 29:37:26TRACK 12 AUDIOINDEX 01 33:13:72TRACK 13 AUDIOINDEX 01 36:49:73TRACK 14 AUDIOINDEX 01 40:19:56TRACK 15 AUDIOINDEX 01 43:54:19TRACK 16 AUDIOINDEX 01 45:21:41TRACK 17 AUDIOINDEX 01 46:04:04TRACK 18 AUDIOINDEX 01 46:49:48
I used PowerISO to extract the Audio files off the disc. Select all the Audio Tracks on your game disc, then "Extract" as a single WAV file. It will create a WAV and the associated CUE file for the tracks. From there you just need to add the first track section for the ISO of the game.
FILE "GAME_NAME_HERE.ISO" BINARYTRACK 01 MODE1/2048INDEX 01 00:00:00
Anyway, maybe this is well known, but I kept seeing everyone across multiple sites and forms claim this was impossible without using BIN/CUE. I will continue to experiement and try to get any other versions of this working and report it here.
Ohh and you can actually combine an ISO file with the BIN to create a Frankenstein BIN+ISO+CUE. This did help with the CD Audio playback, but obviously makes file sizes larger, cause the BIN contains the same CD Files as the ISO.
That looks like this:
FILE "EXPANSION.ISO" BINARYTRACK 01 MODE1/2048INDEX 01 00:00:00FILE "WARCRAFT2_X.BIN" BINARYTRACK 02 AUDIOPREGAP 00:02:00INDEX 01 19:52:05TRACK 03 AUDIOINDEX 01 19:58:07TRACK 04 AUDIOINDEX 01 26:28:66TRACK 05 AUDIOINDEX 01 33:40:53TRACK 06 AUDIOINDEX 01 37:22:59TRACK 07 AUDIOINDEX 01 40:59:12TRACK 08 AUDIOINDEX 01 41:57:15TRACK 09 AUDIOINDEX 01 42:35:01TRACK 10 AUDIOINDEX 01 43:32:30TRACK 11 AUDIOINDEX 01 49:29:31TRACK 12 AUDIOINDEX 01 53:06:02TRACK 13 AUDIOINDEX 01 56:42:03TRACK 14 AUDIOINDEX 01 60:11:61TRACK 15 AUDIOINDEX 01 63:46:24TRACK 16 AUDIOINDEX 01 65:13:46TRACK 17 AUDIOINDEX 01 65:56:09TRACK 18 AUDIOINDEX 01 66:41:53
