First post, by Kenichi-san
Hello guys,
I'm trying to configure the Autoexec section of Dosbox. I downloaded DOSBOX for Windows and I added these lines :
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
MOUNT C C:\DOSGAMES\
C:
I saved and ran Dosbox.exe, it worked !
I'm doing the same thing for `Dosbox in Fedora 30`, configuring the file `dosbox-0.74.conf` located in `/usr/share/dosbox/translations/fr`.
But when I run it, it doesn't work.
Here is a screenshot :
It worked for Windows...
I tried to put these lines on each `dosbox-0.74.conf` located in each translation folder, but still not working.
I think that the application doesn't run this configuration file, it seems to be another file, but which one?
I've made a search of `dosbox` and these were the only files existing.
Reply 5 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's a hidden folder in your HOME folder (~ means your HOME folder and the dot before the name means it is hidden)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
DOSBox SVN snapshot for OS X (10.4-10.14 ppc/intel 32/64bit) codesigned for gatekeeper
DOSBox SVN with SDL2 snapshot for OS X (10.7-10.14 intel 64bit) codesigned for gatekeeper
Reply 7 of 7, by Dominus
DOSBox Moderator
Great! And good that you knew how to make it appear, as I'm not on Linux and wasn't able to tell you that 😉
