First post, by Kenichi-san
Hello guys,
I'm trying to configure the Autoexec section of Dosbox. I downloaded DOSBOX for Windows and I added these lines :
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
MOUNT C C:\DOSGAMES\
C:
I saved and ran Dosbox.exe, it worked !
I'm doing the same thing for `Dosbox in Fedora 30`, configuring the file `dosbox-0.74.conf` located in `/usr/share/dosbox/translations/fr`.
But when I run it, it doesn't work.
Here is a screenshot :
It worked for Windows...
I tried to put these lines on each `dosbox-0.74.conf` located in each translation folder, but still not working.
I think that the application doesn't run this configuration file, it seems to be another file, but which one?
I've made a search of `dosbox` and these were the only files existing.
Reply 2 of 7, by Kenichi-san
In which folder?
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
~/.dosbox
(mentioned in the README/manual btw)
Water flows down the stream
Reply 4 of 7, by Kenichi-san
Can you tell where to find this folder? I've looked everywhere, impossible to find it.
Reply 5 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's a hidden folder in your HOME folder (~ means your HOME folder and the dot before the name means it is hidden)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 7, by Kenichi-san
Thank you very much, I did Ctrl+H on the root folder, and dosbox appeared. Magic.
