GUS problem in DOSBox 0.74-3
General information and assistance with DOSBox.
Postby slx » 2019-7-25 @ 20:38
I used the GUS emulation without any problem since the 0.74 and there wasn't any problem in 0.74-2 but there are a lot of error in the DOSBox 0.74-3 version!
Doesn't load voice samples for example in the basic GUS mididemo; and freezes samples in the SW Dark Forces (the drum froze and play the same all the time).
There weren't these problems in the older DOSBoxes!!!
User avatar
slx
Re: GUS problem in DOSBox 0.74-3
Postby Qbix » 2019-7-26 @ 05:13
Are you using the same settings ? (as the configuration file is tied to version of dosbox).
If so, which settings are you using ?
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby slx » 2019-7-27 @ 01:43
Thanks the answer!
Yes, I use the same settings, I didn't change anything!
Which settings do I use in dosbox-0.74-3.conf or where?
gus=true
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\UTILS\GUS
I configured the GUS in DOSBox by what I found here at vogons
viewtopic.php?t=16974
User avatar
slx
Postby Qbix » 2019-7-27 @ 06:20
The gus emulation itself is identical to the one in 0.74-2. Maybe the environment fixes interfere somehow. Do you have a lot of lines in your autoexec ?
the default configile is indeed dosbox-0.74-3.conf
*moved to dosbox General*
User avatar
Qbix
DOSBox Author
Postby slx » 2019-7-27 @ 21:02
i didn't modified the GUS config at all in dosbox.
This is my config edit in the .conf now:
„[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
SET PATH=C:\UTILS;C:\UTILS\GUS;C:\UTILS\DN;C:\UTILS\ZIP250;C:\UTILS\CDPLAYER;C:\UTILS\SEA;C:\UTILS\PSVIEW;
rem MOUNT a A:\ -t floppy
mount c F:\old\PCDOS
mount d K:\dosboxd
mount e N:\ -t cdrom
imgmount f K:\dosboxe\BAT2_CD\cd\bat2.bin -t cdrom
imgmount g E:\Games\PC_on_E\EWJ2_CD.cue -t iso
mixer CDAUDIO d-15 ; gus d-5
c:
dn
The F, G CD-ROMs are permanently, now.
The dosbox-0.74-3 does not load when I start the program a lot of time. I have to close it down and start again.
The SW Dark Forces GUS music gets problem in the into. I tried to change the digital channel to Sound Blaster but it didn't get anything better with the GUS music audio (because it is a different channel but I tried everything).
User avatar
slx
Postby slx » 2019-8-01 @ 21:50
I have tried on a Win7 system a 0.74 with the same DOSBox setup and the GUS problem exists there too!
SO, THE PROBLEM IS IN MY DOSBox - GUS setup!
I do not know what is the problem but it started when I updated the GUS software in DOSBox.
I think there isn't any problem with the DOSBox 0.74-3 GUS!!! I'M SORRY!
User avatar
slx
Postby slx » 2019-8-02 @ 23:34
I solved the problem when I download a complete ULTRASOUND directory (I do not know where can I check the version of this software) from the page
http://www.pc-freak.net/blog/enable-gra ... xperience/
because I had problems because I did everything what I read on the page
viewtopic.php?f=31&t=16974
but I can not use the 'Install UltraSound Software' after the 'Restore File(s)' option because it says 'Unable to Determine Card Type '.
I installed the previous GUS software version on 0.74 long ago and updated it (+ the Pro Patches) on 0.74-2 and I found the mentioned errors on 0.74-3.
Please, help me! What did I do wrong? Is what cause the 'Install UltraSound Software' error?
User avatar
slx
Postby slx » 2019-8-05 @ 16:16
One more and final thing.
I downloaded an updated ULTRASND folder from here.
I found something what does not the same what I saw in a YT video. https://youtu.be/eyqBTeoeg6A?t=1331
There is a different instrument (midi note 13) in my GUS emulator what I hear in the video around at 22:12.
I hear like a (cow) bell in the video but there is something else in my DOSBox GUS emu. :(
https://youtu.be/-2h-WrQfytc
:D
User avatar
slx
Postby K.A.R.R. » 2019-8-14 @ 20:44
if it sounds different, it's because some people on yt use standard patches and some use pro patches lite
K.A.R.R.
Return to DOSBox General
Who is online
Users browsing this forum: Silanda and 3 guests
