First post, by elund
I would like to run a progam (.bat file) in DOSBox, but it requires a DOS PATH.
Is it possible to set DOS PATH like in autoexec.bat in a normal DOS environment? Example: Path = C:\Windows; C:\Windows\Command;C:\Vet;
Or is there a work around of this problem?
