Nice scaling of Discworld II?
General information and assistance with DOSBox.
Postby andylatham82 » 2019-8-22 @ 07:53
I use DosBox SVN Daum to run my old DOS games. I use that version because of the nice options for CRT shaders. I love how older DOS games in a 320x240 or 320x200 resolution look. Even without CRT shaders, the pixel art looks great scaled up on a modern monitor. Later games with a 640x480 resolution don't look good with a CRT shader because the scanlines don't scale well on a 1080p screen. So in those cases I just keep the raw pixels.
However for Discworld II, which uses a higher 640x480 resolution, there seems to be no way to make the artwork look nice on a 1080p screen. I'm not sure if it's how the art was originally digitized, but that game just looks ugly in any way I can find to display it (other than having a tiny original-resolution window). The best option I've found is an anti-aliasing shader, but that also makes things look quite blurred. It's such a shame as the underlying artwork is nice, it's just got horrible jagged edging.
I wondered if anyone might know of a good solution?
Thanks!
andylatham82
Re: Nice scaling of Discworld II?
Postby root42 » 2019-8-22 @ 08:27
Can you post a screenshot? Of course one problem is that 1080 is not a multiple of 480. you could try to force a 2x scaler, which gives 960, with black bars. That might look nicer.
Soldering, retro game reviews and more on YouTube and Bonus videos
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, Jazz16, PC MIDI Card + SC55MkII + MT32, XT CF Lite, OSSC 1.6
User avatar
root42
Postby andylatham82 » 2019-8-22 @ 09:31
Using a 2x scaler, I was able to get the resolution you suggested, but there was no way of getting it to play nice with any of the CRT shaders. That's not the end of the world, but I did manage to make some further progress.
Instead of using a 2x scaler, I manually set the resolution of DosBox for that game to 1280x960, and made sure that my graphics card didn't do any additional scaling. After applying a CRT shader, I was pretty happy with
the result I ended up with (see below). Many thanks for your help :)
Note that the graphics in Discworld 2 give a border at the top and bottom anyway, not using the full resolution of the "screen". In the screenshot I have cropped these off, but the on my computer monitor the game basically has a black border all the way around. I'd love to be able to scale up to the full 1080p, but I don't think this is possible while keeping the game looking nice. This game, more than others, seems to suffer badly when using non-integer scaling, regardless of any scanlines used.
Also make sure you're looking at this at full resolution so that the scanlines aren't distorted.
andylatham82
Postby root42 » 2019-8-22 @ 09:52
I think this looks rather nice.
User avatar
root42
Postby collector » 2019-8-22 @ 15:05
Note that Daum is very old and broken. Use official DOSBox 0.74-3.
User avatar
collector
Postby krcroft » 2019-8-22 @ 15:34
root42 wrote:I think this looks rather nice.
I agree.
Andy, would you be able to post some comparison captures of the lower res sources that you mentioned (320x200/240) scaled up using your preferred CRT shaders versus the baseline DOSBox? Thank you!
User avatar
krcroft
Postby KainXVIII » 2019-8-22 @ 19:42
collector wrote:Use official DOSBox 0.74-3.
Does not support shaders tho.
User avatar
KainXVIII
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 4 guests
