Quake 2 in DosBox
General information and assistance with DOSBox.
Quake 2 in DosBox
Postby ALCoL » 2019-8-30 @ 20:31
Hi, i tried to run Quake 2 from here and i try many configs with gl and glides and whatever but simply i cant, it doesnt load, i have w7 x64 and last version of dosbox with dosshell frontend, can u gimme lil help? thanks in advance :cool:
ALCoL
Re: Quake 2 in DosBox
Postby ShovelKnight » 2019-8-30 @ 20:49
Quake 2 is not a DOS application.
ShovelKnight
Postby Bondi » 2019-8-30 @ 20:51
AFAIR there is a DOS port of Q2
Bondi
Postby DosFreak » 2019-8-31 @ 00:40
IIRC Q2DOS isn't supported in DOSBox or any other emulator and the only way it will work with glide in DOSBox is with kekkos voodoo emulation patch which currently isn't in official DOSBox and when Q2DOS is run with it then the game is very slow. You would be better off using pcem or qemu or better yet run the game in real DOS or use the Windows version of Q2DOS or the other five million ports.
User avatar
DosFreak
Postby jmarsh » 2019-8-31 @ 04:05
Works fine in DOSBox 0.74-3 with memsize=63.
jmarsh
Postby ALCoL » 2019-9-01 @ 02:14
DosFreak wrote:IIRC Q2DOS isn't supported in DOSBox or any other emulator and the only way it will work with glide in DOSBox is with kekkos voodoo emulation patch which currently isn't in official DOSBox and when Q2DOS is run with it then the game is very slow. You would be better off using pcem or qemu or better yet run the game in real DOS or use the Windows version of Q2DOS or the other five million ports.
Yeah thats my plan b, i have seen Q2 dosbox but I expected to find a way to run it
ALCoL
Postby ALCoL » 2019-9-01 @ 02:17
jmarsh wrote:Works fine in DOSBox 0.74-3 with memsize=63.
what it means??
ALCoL
Return to DOSBox General
Who is online
