Windows 10: Can't get fullscreen to work
First post, by Forklift17
I've looked at several tutorials for how to get DOSBox fullscreen. I have tried multiple settings for fullresolution, windowsresolution, output, etc. in the config file. Nothing I have tried works. The best I can do is to get a large window that only has a tiny portion in the middle for DOSBox, and the rest of the window is black.
I know that most DOS games have a 4:3 aspect ratio, and this is fine, but this does not describe my problem.
How do I enlarge DOSBox to fill most or all of the screen, not just that tiny portion in the middle?
Reply 4 of 6, by Forklift17
jmarsh wrote:
change output to opengl in the .conf file. Also set aspect to true if you don't want the original 4:3 screen stretched on a widescreen monitor.
I fixed it. I was commenting out stuff with #, but it seems you can't do that on the setting lines. I set the fullscreen resolution to 0x0, and now it's truly fullscreen.
Thanks for the help, everyone!
