When I try to run certain things, it says "Out of Memory! Try unnloading your TSRs". I changed the dosbox maximum memory in dosbox.conf to 64 megabytes. I KNOW that is enough memory. How can I change that?
I have a Mac OS X computer.
I don't understand, what am I suppose to put in with the command to replace: [-size] [program] [program-parameters] in the command loafix [-size] [program] [program-parameters]?
Stockholm, Sweden, Europe, Earth Interests: Old games & young women
Well, if you buy me a 2-way 1st class air ticket, a taxi ride from the airport to your home and back, I will come and install the game for you. My best estimate is that I can get it up and running in 2-3 hours (for which I will charge you $100 per hour). Of course, if I fail to get it up and running, I will void those $300.
Thing is, you don't have any TSRs loaded. DOSBox emulates a DOS enviroment that is quite rare and a few programs are really bad at handle it and give out fake errors or simply crash. The "loadfix" command was made to fix that.
And you have still not answered the question, what are you trying to run?
Actually it wasn't a lockup...it just took awhile to export the graphics. So modkeen works fine here as far as exporting the graphics goes. I'm using Modkeen v2.0.1.
