First post, by Kanangea
when i put mount c c:\dosprog on dosbox 0.62 it says directory c:\dosprog doesn't exist what do i do ive been trying for more than 1 hour!!!!!! 😵
Reply 2 of 10, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Are you sure that the directory exists? i have never heard about any problem with simple mounting like this...
Also post in the proper forum next time and choose better title.
Mirek
Reply 4 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
uhm c:\dosprog
The directory in question is the dosprog directory on C:\
you might want to try this
mount c c:\
Water flows down the stream
Reply 5 of 10, by MiniMax
Rank Moderator
Moderator
Kanangea, download one of the DOSBox frontends (e.g. D-Fend or Boxer) and use that to configure DOSBox with. I think a user-friendly, graphical frontend will make it much easier for you to use DOSBox.
_________________
