dreamer_ wrote:
I use primarily Linux and implemented several workarounds for DOSBox SDL 1.2 issues in Boxtron (including workarounds for fullscreen issues). Can you share some more details about your setup? (what distro, what version of DOSBox, X11 or Wayland, etc)?
I'm running it on a raspberry pi, on raspbian which is a debian branch. I'm not running a desktop environment like Xorg et al. I think I've read somewhere that the fullscreen mode functions if I install xorg, but I don't think running dosbox in xorg is optimal because of performance issues. Still, if that's the best option to get the resolutions to match right, maybe I should. Sorry if I'm ignorant here...
I just tried it again, and it's behaving very weirdly. I queried my console with fbset -s and confirmed 320x200 system resolution (I changed it from 640x480 to test), but then when I try to launch a 320x200 game in dosbox, I get a tiny square in the middle of the screen. If mess around with scaling, I can get it to stretch out, but I think the image gets jacked-up. Shouldn't a 320x200 res game in dosbox fill the screen (using surface, no scaling)if my system resolution is set to 320x200?
