First post, by Guest
Hi everyone, I'm having a problem with colors being overly bright and washed out when I run DOSBox (0.62) in full screen mode. This is under Windows XP SP2. In windowed mode, the colors look fine.
I can use the ATI Catalyst Control Center to decrease the gamma/brightness of my desktop display (making it overly dark) and then go into full screen mode with DOSBox and the colors will appear normal, but this is a hassle.
Is there any way to alter the brightness/gamma settings for DOSBox only, or preferably, for DOSBox and only in full screen mode? Or any other more convenient solution/workaround to the issue I'm encountering?
Sorry if this has been covered, I tried searching the forums and the readme file and didn't see anything that helps.
