First post, by Schuppe
However, why it is not Fixed?
In All Headless SDL Sessions Scancodes=true not Working, its no problem, but its not Possible to use "Umlauts" and other Special chars on scancodes=false.
In Headless Modes Linux dont add 8 to scancodes.
What is the Workaround?
The Problem is:
#if !defined (WIN32) && !defined (MACOSX) && !defined(OS2) && !defined (HEADLESS)
/* Linux adds 8 to all scancodes */
else key-=8;
#endif
Howto reproduce?
Install any minimal Linux OS Image, install dosbox and type anything with "scancodes=true" most enabled in Basic Configuration.
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
what is HEADLESS ? (hint, that might be why isn't fixed)
What defines that ?
(is it something SDL does ? or your OS ?)
Water flows down the stream
Reply 2 of 8, by Schuppe
Headless means non Graphical Enviroment without Desktop, only Console uses SDL/FBcon automatically.
How to reproduce:
Install any minimal Linux OS Image without Desktop (Fedora,Debian)
install dosbox and type anything with "scancodes=true" most enabled in Basic Configuration. (For my Site keyboardlayout=de129)
Now as example Type "L" and see "A" was drawn in Dosbox.
Reply 4 of 8, by Schuppe
Ah sorry i have copied the wrong file (own Workaround in Progress), i comment out this Lines for my Headless use.
SVN sdl_mapper.cpp:
else key-=8;
#endif
Reply 7 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
you mean the environment one ? I don't think that one is set by default. The user can set it to override things.
Reply 8 of 8, by Schuppe
Oh. Find another one. Not tested with svga and directfb.. XVFB same problem.
static char driver[16] = { 0 };
SDL_VideoDriverName(driver, sizeof(driver));
if (::strcmp(driver, "x11") != 0)
EDIT: i have read Informations, its a X11 Problem.. Wayland not adds 8 on Scancodes.
