First post, by Phrank
Hi guys,
does it exist a Dosbox command to start capturing a wav file without using the special key Ctrl-F6 or another remapped special key? Or it is the only way to start/stop grabbing?
I want to automate capturing multiple audio files: I thought to use old keystroke emulation programs (like 'stuffit') but in Dosbox they work only for the simple characters (Ctrl-f6 doesn't work - interrupt problem or similar?); also the character is printed at the prompt but not recognized as pressed.
Can you help me?
Thanks, ciao
