Yes, I've tried swapping disk images, but it doesn't seem to work. I've tried using IMGMOUNT to mount the second disk image out of six of them. I would then run SETUP.EXE on the mounted floppy disk drive, which contains the files of the first disk, and then when it came time to swap disk, I'd try pressing ctrl-F4 to swap the second disk image into the mounted disk drive, but it didn't work. I've also since tried using the BOOT command to mount all six disk images, but that doesn't seem to work either. One approach I'd take is to use the BOOT command to mount all six disk images on the virtual A drive and make sure that the first disk image was the one that was loaded. Then I would go to the virtual A drive and type SETUP only to get "Bad command or file name." I've tried this same approach again except that I had all the disk images stored in the place that I would designate as the A drive, and I got the same result. Finally, I've tried using the BOOT command on all six of them and made sure that they weren't stored on the place I designated as the A drive. In the virtual A drive, I would instead put all the files that were contained on the first disk there. Then I would run SETUP.EXE from the virtual A drive, but when it came time to swap disks, pressing ctrl-F4 to swap the disk images did me no good. I've even tried saving the files from each disk to a separate CD, and I'd mount the A drive as CD drive. It seemed to work at first, but right before it came time to swap disks, the program would crash, and I'd get this peculiar error message that was something like "rghsource had no drive specified" even though I made sure that each of installation paths began with "C:\".
