First post, by theelf
- Oldbie
Hi, i use dosbox since many years ago, but always for "fun" never like a serious replacement of my real hardware
I decide this 2020 build a dedicated PC just for dosbox and win3x & 9x games
Is a thin client, Futro S550 AMD 1.2ghz, ATI x1250 and a 14" CRT
Dosbox is give me a lot of trouble with the parameter "fulldouble". If i use "true" i have no tearing, but sound is terrible, if i set to "false" sound is ok, but tearing is horrible
I think relevant parameters i use
output=surface
machine=svga_s3
core=normal (& dynamic)
cycles=3000 (3000-25000 deppend game)
blocksize=1024 (i tested with 256-1024)
prebuffer=20
Resolution i create for dosbox
320x200 70hz
320x240 60hz
640x400 70hz
720x400 70hz
640x480 60hz
720x350 60hz
720x348 50hz
Dosbox is using correct resolutions, for example in Wolfenstein 3D, i check is using 320x200 at 70hz, and in Pinball Fantasies 320x240 at 60hz
I check the CPU usage and is very low, like 20% of CPU usage max when wolf3d is running
Any ideas? im stuck
thanks a lot
