First post, by Pan
Hi
Is it possible to boot from a floppy image using the BOOT command while also adding a hard disk image so you have both A and C drives in native mode. I have attempted this, but if I boot from a boot floopy, there seems to be no way to access a C drive. There seems to be no documentation available answering this question, despite my efforts to locate some.
I unfortunately do not have a bootable hard disk image, so I wanted to transfer OS files from floppy to hard disk using the sys command. However, it seems impossible to mount them both at the same time.
Anybody know how to mount a floppy and disk image at the same time while using the BOOT command?
Thanks
Pan
