First post, by pest
hello!
i've a problem with ver 0,63:
on opening a dos program "budenberg" under doxbox emu, the emu crashes an leaves the following message:
DOS:0x65:unhandled country information call 21
i've no idea what this error messages means.
is it possibe to create a config.sys file to load some county parameters?
if yes, where should i place the file?
thank you!
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
there is no config.sys to do that.
We put the message there to see if somebody/something actually used that call.
Water flows down the stream
Reply 2 of 6, by pest
thank you!
i searched the web for this error message, but without success. now im looking for a debugging feature in dosbox to find a solution. im not a programmer, so im looking for a debugging howto.
btw:
in an earlier version of dosbox the program budenberg works. but not all parts of the programm - only the first menue.
useing version 0.63 the first menue doesnt work (dosbox exits with the described error message) but the other program parts dont. 🙁
stephan
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
http://www.delorie.com/djgpp/doc/rbinter/id/77/31.html
that's the call
your program is the first we know that uses this call
	    21h capitalize string
DS:DX -> string to capitalize
CX = length of string
Shouldn't be that hard to add. It was never needed though.
if you can compile dosbox yourself go to src/dos/dos.cpp:834
and replace that line with a ;
it's a work around and maybe it works.
Reply 4 of 6, by Guest
thank you - now it works!
maybe you can put some code to one of the next versions, so that this fix has not to be done in the sourcecode of the debian packages. I'm a maintainer of an austrian school project that is trying to create a linux terminalserver/samba solution for schools, based on debian. (www.slixs.at) Now I'm trying to emulate some dos programs (eg budenberg) to work in a linux terminalserver environment. - Next is to make sound work over network. but this ist not that important.
stephan
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
could we get into contact so i could notify you if i coded support for it so you could test if it works ? (e.g. not leads to any crashes ?)
