First post, by Guest
I've libpng 1.2.7 compiled and installed in the correct locations (all under C:\msys\1.0\local):
bin\
__libpng12.dll libpng12-config libpng-config
include\
__png.h pngconf.h
__libpng\
____png.h pngconf.h
__libpng12\
____png.h pngconf.h
lib\
__libpng12.a libpng12.dll.a libpng.a libpngdll.a
__pkgconfig\
____libpng12.pc libpng.pc
Other libraries are detected and used well in those locations, but DOSBox 0.63 refuses to detect it. In the ./configure step it says:
checking png.h usability... no
checking png.h presence... no
checking for png.h... no
checking for png_check_sig in -lpng... yes
configure: WARNING: Can't find libpng, screenshot support disabled
It doesn't detect them even in the case that you move the includes and library files to the standard locations C:\MinGW\include and \lib. However DOSBox detects SDL libraries (at the same locations), compiles and runs OK but lacks screenshot support. What can I do to make it detect libpng ?
I'm interested in recompiling DOSBox to gain some performance by activating -march=... and other optimization flags. I've got 20500 cycles so far running Doom 2 with GUS playing at 44100 KHz and no frameskip in my Athlon XP 2400+. With the standard build I got 18000.
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
c:\msys\1.0\local the right location ? Really ? it seems a odd location
anyway just add the include directores to the CXXFLAGS before starting dosbox.
dosbox uses the default search path of the compiler.......
Water flows down the stream
Reply 5 of 7, by Guest
Thanks a lot for all your answers. Just only one more question: assumed that you use MinGW to compile DOSBox... what did you do to compile against the SDL_sound library ? I get a bunch of errors when building the library related to string.h and math.h definition conflicts (duplicated definitions):
../.libs/libSDL_sound.a(libmpglib_la-interface.lo)(.text+0x50): In function `_isnan':
C:/MSYS/mingw/bin/../lib/gcc/mingw32/3.4.2/../../../../include/math.h:338: multiple definition of `__isnan'
I've seen out there that it's a common problem (not only mine) with latest MinGW, but I didn't find any solution.
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well the trouble is sdl_sound itself.
it has a lot of problem and we had to modify it source.
I recall that you have to modify the file sdl_sound_internal.h
and look for a undefinition of inline
that is wrong and should be a defintion.
