Dosbox for macbook
Reply 21 of 33, by DosFreak
Assuming you are not a troll.
If you want help then you need to provide details.
1. Post exactly what you are trying to do with text and/or images.
2. Where are you downloading DOSBox from?
3. How are you installing DOSBox?
4. How are you launching DOSBox?
5. What commands are you using inside DOSBox?
If the next post is the same as the prior posts then the thread will be locked.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 26 of 33, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Just for future reference you mean macOS Catalina, iOS is for the iphones.
And nothing in useability changed much with Catalina (except 32bit apps don't work anymore)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 29 of 33, by root42
nieckar44 wrote on 2020-05-04, 14:58:
i updated my MacBook to Catalina and it won't work it used to work with my last iOS
just tried to down load boxer and it won't let me install it
Yes, just like I said above. The official Boxer distribution is not compatible with Catalina, due to the removed 32 bit support.
The version I linked above should be 64 bit compatible, from what I gather. I built it myself. However, you have to right click to open it. Otherwise the macOS gatekeeper will disallow running it, since I don't have a valid macOS developer account for signing binaries. Please try right clicking and selecting open and acknowledge in the dialog that pops up then that you REALLY want to run Boxer.
YouTube and Bonus
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, SnarkBarker & BlasterBoard, PC MIDI Card + SC55 + MT32, XT CF Lite, OSSC
Reply 30 of 33, by root42
nieckar44 wrote on 2020-05-14, 16:34:
last question can you get dosbox to work on a iPad
Good question. I know that DOSPad used to work (https://litchie.com/dospad). But I don't think this is up to date anymore. But you might check the AppStore if it is still available.
YouTube and Bonus
Reply 31 of 33, by root42
nieckar44 wrote on 2020-05-14, 15:12:
just managed to get boxer to work
Oops, overlooked the newer answers. That's great. Did you use my binary?
YouTube and Bonus
