First post, by alucard
Hiya, I;ve just started using DOSBox and it's really good. However, I cannot seem to get sound on any of my games. The only one I have heard sound on is settlers II (and all I hear then are the birds). I have a SB Live! soundcard, and all my non DOs sounds are fine.
Please help!
Reply 1 of 1, by MiniMax
Rank Moderator
Moderator
alucard, I suggest you install one of the DOSBox frontends and use that to enable/disable the various soundcards that DOSBox emulates.
With the right "cards" and settings in the games to match what you have enabled, I am sure you will get all the sound you like.
_________________
