First post, by lwc
Hi!
Let's say I want the default conf file...except one value.
The thing is, if I copy the entire file and then change the one value, it will surely cause problems by next release (since you change the conf file somewhat with each new version).
The question is if I can just have a little file with, say:
[cpu]
core=dynamic
(I know the titles are a must).
This way the chance of you changing this value of all things is much lower and I probably won't have to mess with this file in future versions.
Plus, it makes it easier for me to remember what exactly differs this game's settings from the default conf file.
So is it legit?
Will DOSBox just take the default values for everything else?
I know it does for sound, memory, frame skip, cycles, etc. but it's harder to know about other values.
If so, I think I'll start having local conf files and stop relying on "-conf c:\program files\dosbox\dosbox.conf".
