First post, by _Rob
I want to experiment with some games, like Dune 2, that support Roland GS (Sound Canvas) devices, and need a good GS soundfont. I found some soundfonts that purport to emulate the SC-55, but they don't sound right when compared with a real Sound Canvas. Missing sounds, or incorrect sounds.
I would like to try FluidR3_GS, but that is only a supplemental soundfont, and requires that you first load FluidR3_GM.
The problem is, that the FluidSynth support built into DOSBox ECE and DOSBox-X only allows you to specify a single soundfont, so you cannot do any "stacking" or "chaining" of soundfonts.
Is there a simple way to "merge" two soundfonts into one? Preferably on Linux.
Reply 1 of 18, by Joseph_Joestar
I have no experience with soundfont merging, but I can highly recommend Patch93's SC-55 soundfont. It sounds the closest to the real thing to me. Here's a sample.
You will also need SF Pack to convert it to .sf2 format.
Reply 2 of 18, by _Rob
Joseph_Joestar wrote on 2020-06-19, 14:35:
That is one I found in the past, but never tried because of the stupid sfpack format. There is only the windows binary to convert it, and trying to start SFPACK.EXE in Wine, just throws a page fault.
Reply 3 of 18, by Joseph_Joestar
_Rob wrote on 2020-06-19, 15:29:
I think I once managed to unpack it in VirtualBox running WinXP+SP3.
I always keep one of those handy since I'm mostly running CentOS on my main rig nowadays.
Reply 4 of 18, by _Rob
Managed to get it converted and noticed quite a few issues during the dune 2 intro, where the sounds are just wrong compared to a SC-88Pro
https://www.youtube.com/watch?v=SiaoxTph0QU&t=349s
-The part with the two harvesters, where one gets picked up and the other settles down
-The part with the armies arriving, when the transport craft lands
-The part with rocket launchers (sounds like a telephone sound instead of the woosh)
Reply 5 of 18, by Joseph_Joestar
_Rob wrote on 2020-06-19, 16:29:
From what I understand, the SC-88 doesn't quite sound the same as a SC-55. It does have a SC-55 mode, but even so, some minor differences remain.
Granted, it could very well be that the differences in your example come from the soundfont, as the author states that he couldn't perfectly implement all the instruments. But to be sure, you should compare apples to apples i.e. soundfont vs. real SC-55. Like this:
Doom E1M1 with Patch93's SC-55 soundfont
vs.
Doom E1M1 on a real SC-55
The differences may be more pronounced in other games, but in Doom and Duke3D, Patch93's soundfont sounds reasonably close to the real thing to me.
Reply 6 of 18, by _Rob
Also tried this SSC1 (Should be SSC-I...) soundfont from here: http://www.vogonsdrivers.com/getfile.php?fileid=500
-The part with the two harvesters, where one gets picked up and the other settles down - sound missing
-The part with the armies arriving, when the transport craft lands - not perfect, but better than Patch 93's SC-55 soundfont.
-The part with rocket launchers - sounds a little more like rockets
Reply 7 of 18, by _Rob
If anyone wants to try Patch93's SC-55 soundfont and not having to worry about converting it to sf2, you can now get it from here: https://musical-artifacts.com/artifacts/1228
Reply 8 of 18, by _Rob
Tried Emporor Grieferus's SC-55 soundfont (Roland SC-55 v3.7.sf2), available here: https://archive.org/details/SC55EmperorGrieferus
As already warned on the download link, it seems fine for General Midi, but lacks the GS extensions. So the sound effects in the intro of Dune II are all wrong.
Reply 9 of 18, by _Rob
Comparing real Roland SC-55 to SC-88Pro
SC-55: https://www.youtube.com/watch?v=TK5TwFaKA2M
SC-88Pro: https://www.youtube.com/watch?v=SiaoxTph0QU&t=349s
- Westwood splash screen, the sound is sustained longer on the SC-88pro
- Generally the sounds seem a bit "richer" on the SC-88pro
All in all, minimal differences. All the sound effects used in the intro are present on both, and seem pretty similar.
Reply 10 of 18, by Falcosoft
Joseph_Joestar wrote on 2020-06-19, 16:44:
Th problem is Patch93's SC-55 soundfont contains only the so called capital tones (meaning no variation tones, only bank 0 is implemented). So it's not GS compatible at all, it can only be used by titles using only GM instruments.
You could try my Reality GMGS falcomod (version 1.2) soundfont that does not try to mimic Sound Canvas but contains GS compatible variation banks:
http://falcosoft.hu/softwares.html#midiplayer
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 11 of 18, by _Rob
Falcosoft wrote on 2020-06-21, 08:56:
Thanks for the pointer! Not bad, most of it sounds pretty good actually. This is probably the best soundfont for GS games I have come across so far.
The only thing that really stood out was the rocket launchers, where instead of a "woosh" it sounded more like an animal barking.
Reply 12 of 18, by Joseph_Joestar
Thanks for the clarification!
Am I correct in assuming that if you run setup.exe of a game and choose "Roland Sound Canvas" as a music device, the game will try to use GS. But if you choose "General MIDI" instead, the game will only use GM. Or is there some other factor that needs to be taken into account?
Also, I just noticed that Dune 2 only offers Sound Canvas but not General MIDI in its setup. While Doom, for example, offers both.
Reply 13 of 18, by _Rob
Joseph_Joestar wrote on 2020-06-21, 11:02:
Thanks for the clarification! […]
Dune 2 does not have a General MIDI option. You can select either MT-32 or Sound Canvas for MIDI options. And Sound Canvas means it will use GS.
It all depends on the game, generally speaking for games is this era, if it supports MT-32 it will also have General MIDI. Dune 2 is a bit strange in this regard, where it has Sound Canvas instead, which means something like a Roland SC-55, SC-88 or SCC-I.
7.2 KiB
Reply 14 of 18, by Joseph_Joestar
_Rob wrote on 2020-06-21, 13:45:
Yeah, I didn't play Dune2 much back in the day so I never noticed the lack of General MIDI until now. If selecting Sound Canvas in setup expects GS, then anything that's not GS compatible will of course produce suboptimal results.
That said, I just loaded up CT4MGM.SF2 tried Dune2 with that and the intro sounded much nicer than with Patch93's. For reference, this the default sound font which Creative shipped on the Audigy2 ZS install CD. It's doesn't try to imitate a SC-55, but it does seem to support GS. If you want to try it, you can find that soundfont on the driver CD under \Audio\Common\SFBank\CT4MGM.SF2. It's only 4MB in size though, so I gather Falcosoft's soundfont will still be better.
Reply 15 of 18, by Falcosoft
Dune 2 is special in the sense that it supports Sound Canvas not only as a music device but also as an effect device. For 99% of games even if they list Sound Canvas as possible music device usually it simply means GM. Even in case of Dune 2 if you select Sound Canvas as music device a GM only soundfont produce satisfactory result. The problem is when you select SC as an effect device and your soundfont is only GM compatible (so it misses special effects such as Machine Gun, Explosion, Door etc). If you select SC as effect device the game sends special GS effects to Channel 16. If you select Sound Blaster for effect it uses digital samples instead. (It's a little bit confusing that digital samples is a 3rd category in setup and refers mainly to digitally sampled speech.)
Reply 16 of 18, by _Rob
Falcosoft wrote on 2020-06-21, 15:59:
That actually depends on the version of Dune 2, or the setup.exe version it seems. The version I had originally was more limited in options, but after installing a newer setup.exe I can now select all 3 individual. Meaning I now also get speech in combination with either Sound Canvas or MT-32.
https://www.pcgamingwiki.com/wiki/Dune_II:_Th … ng_of_a_Dynasty
Reply 17 of 18, by Falcosoft
Anyway I have merged FluidR3_GM + FluidR3_GS to FluidR3_GM_GS.SF2. You can download it here:
https://drive.google.com/drive/folders/1aDjSB … bL9?usp=sharing
Reply 18 of 18, by _Rob
Falcosoft wrote on 2020-06-21, 20:37:
Thanks! I just gave it a try, and it worked perfectly. All the GS sound effects in Dune 2 worked great.
