First post, by elektroschock
When in Fullscreene mode the screen is switched 90 degree, so the graphics are vertical, centered to the middel
My current screen resolution is
no problem in executing in windowing mode.
My current grpahics setting is true color 1024x768
a systray tool called Intel Extrem grpahics 2 for Mobile is installed where i can set the ordinary screen resolution.
Reply 1 of 10, by elektroschock
my screen is turned 90 degrees, so it is vertical and centered. cannot use full screen mode anymore,
Moderator edits: Merged posts. elektrochock, please do no post the same problem in multiple catagories
Reply 2 of 10, by Snover
You've probably got your Intel "Extreme" (ha!) set up to have the screen rotated at whatever resolution it is being changed to. Disable rotation in the Intel Extreme Graphics control panel.
Yes, it’s my fault.
Reply 7 of 10, by eL_PuSHeR
Higher? !!! That's a lot of free conventional memory. In fact, that's the best you could get. Even in the ms-dos era no one would be able to free more than 625KB+ of conventional memory. 😳
Reply 8 of 10, by DosFreak
Nope, IIRC, I was able to free up 631kb with QEMM back in the day. This was probably without much loaded tho. You could probably do a bit better off with Real DOS nowadays since FreeDOS has TSR's that take up far less memory.
Make your games work offline
Reply 10 of 10, by gulikoza
Who needed 640K anyway 😁. No really, I don't remember any game that needed more than, say, 610-615KB conventional memory all easily achievable if you knew how to tweak config.sys (QEMM was sometimes unstable for me). And dosbox? Why on earth is 637KB not enough and why would those 3 extra kb make a difference?
