First post, by Mark_81
Hi guys
I set Dosbox with
fulldouble=false
I noticed a slight but annoying flickering when moving from right to left...
Why?Does that happen to you?my monitor has a fresh rate of 60 hz
I wanted to report it to the staff
Reply 4 of 24, by DosFreak
ScummVM isn't an emulator.
Post your DOSBox config.
List the games you are playing
List the DOSBox version used
List your Monitor make and Model
List your OS
List your graphics card
List your graphics card drivers
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 5 of 24, by Mark_81
The Secret of Monkey Island
DOSBox.ECE
Dell U2415 60 Hz fresh rate
Nvidia GeForce GTX 1050 TI
Windows 10 Pro
Config BOSBOx.ECE
fullscreen = true
fulldouble = true
fullresolution = desktop
windowresolution =
output = opengl
autolock = true
sensitivity = 100
core = auto
cputype = auto
cycles = auto
cycleup = 10
cycledown = 20
waitonerror = true
priority = higher,normal
mapperfile = mapper-ECE.map
usescancodes = true
frameskip = 0
aspect = true
scaler = normal5x
glshader = none
Reply 7 of 24, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Can you please confirm the issue in lockstock Dosbox?
And please always state what Dosbox version you are using?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 24, by Qbix
Rank DOSBox Author
DOSBox Author
60 hz is under some of the resolutions set by DOSBox.
maybe try frameskip=1 although not sure if it will help for all outputs
Water flows down the stream
Reply 10 of 24, by Dominus
DOSBox Moderator
Dominus wrote on 2020-07-06, 22:09:
Reply 12 of 24, by Dominus
DOSBox Moderator
DOSBox 0.74-3 or an SVN build of DOSBox that has no additional patches applied.
DOSBox-ECE is a fine build but due to various patches it has applied it is prudent to know whether the issue exists in plain DOSBox or was introduced with the -ECE patches. Sorry, should have been clearer.
Reply 13 of 24, by DosFreak
Try disabling vsync in your graphics card
Reply 15 of 24, by Mark_81
I tried with a normal version of DOSBox v 0.74-3 but always occurs the same problem:f licekering Screen
If I buy a new monitor, with a higher refresh rate, the picture of DOS old games, will be smoother without flickering?
