First post, by laxdragon
- Member
I think I've asked about this before. But for some of my games I'ld like to have a in DOS command to change the cycles. I could then via batch files just change the cycles on the fly.
@echo off
config set cycles=2400
stellar7
config restore cycles
See, then I could play stellar7 without having to keypress the cpu, or manually edit the config file each time. Note, with this I'd like to be able to restore the cycles back to the config default with another command.
