First post, by pepeluis
Hi,
I upgrade my notebook to a faster one.
An old dos program not run anymore ( I think is a processor speed problem)
Using the DosBox my program is running now, but this program use the COM 1 to comunicate with a machine and the comunication is imposible.
I modify the config ( direct serial, etc) but I can't comunicate with the device.
Maybe this machine use hardware flow control. Can I do anything?
Can I modify the Dosbox program to use hardware flow control?
Is difficult?
Thanks in advance 😉
Reply 1 of 5, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Is difficult?
What is that "hardware flow control"?
Otherwise:
1. What program is it?
2. Are there any errors reported by DOSBOX?
Mirek
Reply 2 of 5, by Zup
1.- It means CTS/RTS flow control. There was two kinds of flow control with serial ports: Hardware (using CTS and RTS lines) and software (also known as XON/XOFF... you send a XON char, a byte of data and then a XOFF char... repeat ad nauseam). Of course, you may use no flow control... and send all data continuosly.
Reply 3 of 5, by pepeluis
mirekluza wrote:
What is that "hardware flow control"? […]
Is difficult?
Otherwise:
Mirek
Mirek:
Is a program to configure an Radio Equipment.
The program establish communication with the radio automatically using serial port 1 in my old notebook.
With DosBox I can run the soft but the communication is not establish.
How open the COM 1 port the DosBox? Is possible to modify the programation ? I'm not a programmer, I used to program something in VB6.
I want to test with different combinations RTS/CTS, XonXoff and diferrents baudrates.
Any suggestions is appreciated.
Thanks in advance.
Reply 4 of 5, by mirekluza
DOSBox Moderator
The person who knows most about accessing physical serial port in DOSBOX is its author (CANADACOW). He checks this forum occasionaly.
I have never used this functionality (not having any need for it), so I cannot help you any further...
Mirek
Reply 5 of 5, by fish
Are you using the right cable? (Connecting 2 PCs requires a different cable than connecting PC with hardware)
Which baud rate, parity, flow control did you use before? did you use sync or async serial communication?
The Sole Survivor.
Find me on efnet #oldgames
