Reply 20 of 31, by krcroft
- Oldbie
jmarsh,
- the DOSBox-X team has integrated and tested your DMA status register fix: https://github.com/joncampbell123/dosbox-x/issues/1961, and I suspect it will appear in their next release.
- it's been further integrated into DOSBox Staging, https://github.com/dosbox-staging/dosbox-staging/pull/685 with yourself credited as the original author in the commit.
After seeing the documentation that Jon Cambell references, it's indeed a correction and improvement. Thank you.
