DOSBox Feature Request Thread
Reply 240 of 254, by Nicknine
For the record, Retro Wifi SI modem has such a feature. It allows you to map up to 10 7-digit "phone numbers" to network addresses. DosBox HAL9000 build has something like this as well (Re: Direct serial port working).
Reply 242 of 254, by Nicknine
jmarsh wrote on 2020-02-25, 15:00:
Is there a reason you don't just use nullmodem?
Null-modem is more cumbersome to use as you have to constantly change serial1 parameter back and forth while with modem you just set it once and enter the address when starting the game.
Reply 243 of 254, by theelf
Hi, i think a feature dosbox need to have is support for super resolutions, since most if not all new intel graphic cards cant do low clocks, and dosbox is not usable in this gfx cards
a post about this is here
Is there any version of dosbox that supports super resolutions (2560x240,etc)?
Reply 245 of 254, by theelf
jmarsh wrote on 2020-02-26, 01:40:
theelf wrote on 2020-02-25, 23:10:
That isn't true at all, just use a resolution other than "original".
give me a example please, i will check
For example dosbox in a intel gma 950, x3100, x4500 or HD, ati 3xxx, nvidia cards
Reply 246 of 254, by Nicknine
Nicknine wrote on 2020-02-25, 07:53:
I think DosBox could use some kind of "phonebook" feature that would essentially map fake phone numbers to addresses. This would help games where input field does not allow non-numeric symbols and/or is too small for IP address.
I have now set up the build environment for DosBox, I think I can write this feature myself. Does DosBox repo accept community contributions often?
Reply 247 of 254, by EmanuelePulciDoria
@Nicknine
I am really interested in this phonebook feature because the one set up by HAL9000 has been eliminated as he suggests in the following post: Phonebook problem
I am trying to play 688 Attack Sub on multiplayer mode and the nullmodem feature does not work. I have a complete proper post on it. This phonebook feature could be the only fix considering the game only accepts max 11 digits phone numbers.
If you are able to write it would you then be able to share it some way?
Reply 248 of 254, by Nicknine
EmanuelePulciDoria wrote on 2020-03-30, 14:17:
@Nicknine I am really interested in this phonebook feature because the one set up by HAL9000 has been eliminated as he suggests […]
@Nicknine
Here's what I got so far:
dosbox-modem.patch
10.1 KiB
9 downloads
Reply 249 of 254, by EmanuelePulciDoria
Thanks Nicknine, so basically this seems something that needs to be patched in some way to the source file to get a compiled executable of Dosbox with this modification inside. I have no experience in compiling the program and maybe I’m asking a silly question but would it be possible to have directly a Dosbox.zip package with your modification as the one you can download from the Dosbox website?
Reply 250 of 254, by DosFreak
Deleted post.
The topic of this forum is "DOSBox Feature Request Thread", not for issues with compiling.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 252 of 254, by EmanuelePulciDoria
@MasterO, I have seen your link before it was deleted, thank you, very useful. Do you have a thread talking about Dosbox-staging?
Dosbox should definitely have this phone book feature and I really do not understand why it has been deleted.
Reply 253 of 254, by DosFreak
For DOSBox-staging discussion please go to the DOSBox-staging site.
Your other thread is here discussing the phonebook feature: 688 Attack Sub multiplayer mode problems
Reply 254 of 254, by MasterO
EmanuelePulciDoria wrote on 2020-05-26, 21:24:
Please check your private messages.
