DOSBox Feature Request Thread
Reply 240 of 298, by Nicknine
For the record, Retro Wifi SI modem has such a feature. It allows you to map up to 10 7-digit "phone numbers" to network addresses. DosBox HAL9000 build has something like this as well (Re: Direct serial port working).
Reply 242 of 298, by Nicknine
jmarsh wrote on 2020-02-25, 15:00:
Is there a reason you don't just use nullmodem?
Null-modem is more cumbersome to use as you have to constantly change serial1 parameter back and forth while with modem you just set it once and enter the address when starting the game.
Reply 243 of 298, by theelf
Hi, i think a feature dosbox need to have is support for super resolutions, since most if not all new intel graphic cards cant do low clocks, and dosbox is not usable in this gfx cards
a post about this is here
Is there any version of dosbox that supports super resolutions (2560x240,etc)?
Reply 245 of 298, by theelf
jmarsh wrote on 2020-02-26, 01:40:
theelf wrote on 2020-02-25, 23:10:
That isn't true at all, just use a resolution other than "original".
give me a example please, i will check
For example dosbox in a intel gma 950, x3100, x4500 or HD, ati 3xxx, nvidia cards
Reply 246 of 298, by Nicknine
Nicknine wrote on 2020-02-25, 07:53:
I think DosBox could use some kind of "phonebook" feature that would essentially map fake phone numbers to addresses. This would help games where input field does not allow non-numeric symbols and/or is too small for IP address.
I have now set up the build environment for DosBox, I think I can write this feature myself. Does DosBox repo accept community contributions often?
Reply 247 of 298, by EmanuelePulciDoria
@Nicknine
I am really interested in this phonebook feature because the one set up by HAL9000 has been eliminated as he suggests in the following post: Phonebook problem
I am trying to play 688 Attack Sub on multiplayer mode and the nullmodem feature does not work. I have a complete proper post on it. This phonebook feature could be the only fix considering the game only accepts max 11 digits phone numbers.
If you are able to write it would you then be able to share it some way?
Reply 248 of 298, by Nicknine
EmanuelePulciDoria wrote on 2020-03-30, 14:17:
@Nicknine I am really interested in this phonebook feature because the one set up by HAL9000 has been eliminated as he suggests […]
@Nicknine
Here's what I got so far:
dosbox-modem.patch
10.1 KiB
114 downloads
Reply 249 of 298, by EmanuelePulciDoria
Thanks Nicknine, so basically this seems something that needs to be patched in some way to the source file to get a compiled executable of Dosbox with this modification inside. I have no experience in compiling the program and maybe I’m asking a silly question but would it be possible to have directly a Dosbox.zip package with your modification as the one you can download from the Dosbox website?
Reply 251 of 298, by EmanuelePulciDoria
@MasterO, I have seen your link before it was deleted, thank you, very useful. Do you have a thread talking about Dosbox-staging?
Dosbox should definitely have this phone book feature and I really do not understand why it has been deleted.
Reply 252 of 298, by DosFreak
For DOSBox-staging discussion please go to the DOSBox-staging site.
Your other thread is here discussing the phonebook feature: 688 Attack Sub multiplayer mode problems
Make your games work offline
Reply 254 of 298, by Wengier
JessicaJones wrote on 2020-06-29, 23:24:
Hi
I would like Nuked OPL3 added to dosbox.
So it can be set in dosbox.conf next to the existing opl emulators.
DOSBox-X, DOSBox-staging and DOSBox ECE all support this feature now, so try any of them.
Reply 255 of 298, by zerobyzero
Good morning
I think DosBox should implement any form of programming interface or API so users and front-end developers could automate or simplify some tasks. At the moment, there are many things you can automate at the execution of DosBox but once you're inside it, all your options are key shortcuts or dosbox commands (and/or batch files).
(I came to this limitation of DosBox when trying to create a physical interactive control panel for DosBox created with arduino as I explain in this short post Is there any programming interface (or plans for one) to control DosBox).
Regards
Reply 256 of 298, by jmarsh
Pretty much all the options that are "safe" to change at any time other than at the command prompt already have keybinds. Adding different ways of changing other options isn't really worth the effort because it would either require a restart of DOSBox to take effect or likely crash the current program by corrupting memory.
Reply 257 of 298, by dnewhous
AWE32 compatibility, like the iCD version of X-Com. Then get oplemu=compat to work. Then upgrade to OPL4 emulation, which is only found on the Yamaha SoundEdge, a Soundblaster Pro clone.
Could there be a wiki describing the install options of DOSBox - X? The initial decision between DirectX and OpenGL is big, I've tried it both ways and the OpenGL option is much simplified in terms of the size of the install.
Also, for DOSBox, I know it's simpler than DOSBox -X, but couldn't we get rid of the clumsy ctrl F10 method of releasing the mouse cursor?
Is there any way to report something like a Blaster status from the command prompt?
When version was oplmode added as a configuration option?
note: The directdraw install of DOSBox -X has been removed.
Daniel L Newhouse
Reply 259 of 298, by dnewhous
From the wikipedia, for sound effects, the OPL4 can be connected to the Yamaha YSS225 effects processor (EP), which adds various sound effects.
Would that do any good in games?
Daniel L Newhouse
