First post, by hardl
Hallo,
gibt es eine Lösung, wenn DOSBOX unter MacOS 11 nur noch ein leeres Fenster öffnet?
Unter Catalina war alles ok.
Reply 2 of 8, by Salient
Spitz wrote on 2020-11-14, 16:05:
Hi, I do know german, but for all other users - write in english. Moreover it's 21century - there are multiple translators over internet!
Come on, this guy is in total panic which is perfectly understandable 😀
Reply 5 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Make sure that you use the 0.74.3-3 release or a current SVN build (https://www.dropbox.com/s/kbrf5elbcu66kst/Dos … apshot.dmg?dl=0 <- that's the one I do, I also am doing the releases for macOS) and that output is set to opengl in the preference file (~/library/preferences/DOSBox 0.74-3-3 Preferences or DOSBox SVN Preferences).
I do think it's because it is neither a current SVN or the 0.74-3-3 version. There were some fixes needed for macOS 10.14 and newer that are now in the builds.
I did test right now on Big Sur and I had no such problem but the fixes needed were especially for Macs with nvidia or intel graphics cards, so I wouldn't notice that, anyway
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 8, by Dominus
DOSBox Moderator
AFAIK this only affects builds done for the ARM version of Big Sur (or maybe also builds done against the Big Sur SDK). The 0.74-3 versions and my SVN builds of DOSBox *DO* have sound on Big Sur.
