First post, by Guest
Hello,
The database application Gold Info does not work in XP (direct disk access and others). With DOSBOX I was able to run it. Everything seemed allright, only in ones creen Impostant information of a chart is missing. One third of the screen is cut off on the right side. In original DOS, on that screen the font is changed to a smaller one for that everything can fit. In Dosbox this change does not take place, the font stays the normal Console font.
I tried everything, changed the resolution settings, the machine things and so on but nothing changed in that problem.
I would appreciate any answers.
Thanks a lot
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
I think you have encountered a short-coming in DOSBox. I remember someone running a Chinese application in DOSBox who had a similar problem. 2/3 or so of the Chinese signs where missing. If I remember correctly, the conclusion was that the application - and yours too - probably tries to upload the characters into parts of the video-memory. For a hardware VGA/graphics card it will work, but it appears like that functionality is not (yet) a part of DOSBox.
Edit: Yep - here is the thread.
NANPA2: VDMSOUND=Text/Yes, Sound/No. DOSBOX=Text/No, Sound/Yes
_________________
Reply 2 of 4, by Guest
Thank you for your answer.
I do not think, that the program is using - in some way - special fonts that cannot be uploaded. As I said, the screen where the right side is missing is a chart. I suppose the app draws it on its own.
I tired several changes with fullresolution, hwscale and scaler which did not change anything.
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
Did you try changing the machine type? The default is 'vga'. Try 'hercules', 'tandy' or 'cga' (if it is still there).
_________________
