Terminal Serial Port
First post, by ik8ozv
Hi Folks,
i am trying to run a dos terminal program under DosBox but i get an issue.
When i load the terminal and set the parameters for the serial port,
if i just switch OFF and ON the TNC i always get the cmd prompt but if i try to digit anything,
i do not get the cmd back it is like it is blocked and also if i try to switch OFF and ON again i do not
see anything more on the display until i discharge and re load the program again.
Please any help to solve the issue?
Thanks
Enzo
Reply 1 of 9, by Jorpho
I don't understand half your post. What is a "TNC"?
As discussed the last time you were here, if you are using a USB to serial connector, then that may be the cause of your problem.
Serial Port
Reply 2 of 9, by ik8ozv
Hello,
thanks for your reply.
TNC is a Terminal Node Controller and it communicate with the PC through Serial Ports.
It is not a USB to serial connector but a real serial COM1
Thanks
Enzo
Reply 3 of 9, by Jorpho
I still don't understand what you are trying to do.
Can you communicate with this device with a standard Windows terminal program?
Reply 4 of 9, by ik8ozv
Yes i can. Using Putty
The attachment Putty.png is no longer available
This is a list of commands of the TNC that i get when i give the "Disp" command which means display all commands available
Reply 5 of 9, by Jorpho
Okay. And what line are you using in your DOSBox.conf for your serial port?
Are you using the latest DOSBox 0.74-3?
Reply 6 of 9, by ik8ozv
In the .conf file i have used:
serial1=directserial realport:COM1
serial2=directserial realport:COM2
serial3=directserial realport:COM3
serial4=disabled
Yes i am using the last version 0.74-3
Thanks
Reply 8 of 9, by ik8ozv
weedeewee wrote on 2021-02-15, 09:40:
Putty / Terminal / Local Echo / Force On
Please apologise what it is?
Have you read my problem at the first post.?
I am having problems on DosBox not on Putty
Thanks
