Is my problem too complex or do you need more information to be able to help me..?
i was able to get Keen to work on dosbox, but not crystal caves or secret agent. maybe it's because when i downloaded keen there was only one file, and it was the application itself.
when i downloaded secret agent i had three little EXE icons in the folder: catalog, install, and SA1-ASP. i tried running my "secretagent" folder as a directory, but it said it was unable to change to "secretagent." is this bc of the multiple files and what do i have to do to them to make it read the directory?
when i downloaded crystal caves, there is the EXE icon labeled CC1 and a whole bunch of other icons, essential parts of the prog, prolly, that came with the EXE when i unzipped the folder. i tried to set the folder i unzipped to as a directory in dosbox, but once again i got the same message: unable to change to "crystalcaves."
in order for a game to run, is it necessary that the game (the EXE file) be the only thing in the folder(directory)?
*so confused* 😕 i'm trying here... help...!!
roSe
