First post, by sanedu
Hello.
Inside the conf file, what are the rules and best practices regarding the use of paths when one is needed? For example, in the [dosbox] section, there is a "captures:" option. Should you use the path relative to the working directory (the C:/ directory as seen by DOSBox) or relative to the real drive root outside DOSBox?
And how should you write the path? With "" around it?
On other DOSBox releases (ECE, for example), do the same rules apply?
Sorry it this is explained somewhere but I've been searching here and in the wiki and didn't find any clear answer.
Thanks!
