First post, by RaWe
Hy,
dosbox is great but i have a small problem:
I copied the msdos-editor and some other dos-stuff from my old win98 cd to my dosgames-drive. They´re wokring, but i can´t create own commands in the Z:\ drive as .bat as link to them (-> copy failure). What can I do? Can I switch the Z:\drive to "writeable" or add a command-directory?
[sorry for my bad english]
Reply 1 of 5, by HunterZ
The Z:\ drive doesn't actually exist. It's a virtual directory that DOSbox shows you.
You can put your .bat files somewhere on your local hard drive and mount the directory they're in in DOSbox...
