First post, by Shooter
Shooter
Offline
What I must do for seeing a filenames with nonEnglish letters?
DOSBox v0.63, Windows NT/2000/XP
I don't know. Maybe doing a dir /x outside DOSBox will show you the short filename (if applicable). Anyway, just because ms-dos only used 8.3 filenames, I recommend you naming your ms-dos folders using that naming convention.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
