First post, by ub!k
Hi everybody, I spent one hour searching for an answer to my problem, but i havn't been able to find it. So I'm posting now.
I read the faq and the noob instalation guide, I also read the how to post.
So I'm using windows xp family, with sp2 and all the tatest updates.
My video card is ati mobility radeon 9200, my cpu a P4ht 3.0Gh my computer is a laptop...
So Installed dosbox and the french language file as Im french. Then I mounted the directory containing my game which is The eleventh hour. Then I tried to load the directory but it failed, and the message error was: invalid command.
I've read in some faq that sometimes read only folders could provoke errors so I went in mine and tried to remove the readonly, it worked but only for a nanosecond and still I can not avoidthat folder from being a read only and I still get the same message : invalid command...
So please, HELP 😀
Reply 1 of 2, by avatar_58
What commands did you use? Did you mount c:\ or your directory (eg c:\11th)?
Try:
Mount c: c:\
Cd\11th (or your game dir name)
dir (to see the files)
11th (or the name of the exe/com file)
Reply 2 of 2, by Guest
with dir it worked 😀 thanks a lot, now I'm gonna try to set up the video and sound devices...
thanx again avatar_58.
