First post, by zomi
Hy folks.
I'm not a crack. That's the reason for this question.
I've got a DOS program which needs 2.5 MB free XMS.
The Software is used to connect to a serial device.
The software seems to be working fine with Dosbox 0.61 except
the graphics.
But I definitively need direct serial port access. Which is possible
with Vers. 0.63. But unfortunately I'm not able to install the software
from within the Dosbox. Which was possible in Vers. 0.61.
So the software is not able to get a needed configuration file.
Has anyone an Idea how to get this fixed?
Best regards
