First post, by Pyr0
If I had an old program that used to run on DOS and interact with some hardware through a serial port would it work through DOSBox?
I think direct serial port support isn't coded yet (at least officially). I suggest for you to wait until 0.64 is released. If you search the forum, you will find that someone made a working patch.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
