First post, by rael_1970
- Newbie
Hello,
I'm trying to use DosBox for run an old DOS based DB Application, running over network via IPX. The application start correclty but i've a problem:
My application require that the max file handled is up to 180, but the dosbox start with a 110 value. In native MS-DOS was possible to modify this value in the config.sys file.
Someone kwow if is possible to modify it in DosBox?
thank to everyone'll help me!!
Rael
