First post, by Guest
I'm trying to run Ascendancy with DOSBox 0.63 on my Apple iBook (1.2GHz G4). It's a little slow and could do with a few more CPU cycles but I can't increase it using ctrl + F12 as my iBook uses this combination to eject the cd, and I can't remap the key as it also uses F1 to lower the screen brightness. I can write a config file ok and changed the value in it from 3000 to 4000 and Ascendancy ran perfectly until I rebooted, at which point DOSbox stopped loading the dosbox.conf file which it had been doing perfectly well not 5 minutes earlier. I've followed all the instruction in the readme but it still won't load the dosbox.conf file with 4000 CPU cycles (Which is a bit of a bugger).
Any help would be greatly appreciated
