First post, by scratch
Can't be loaded on hard drive.DOS4GW resides on CDrom after installation.Runs from CDrom.Program asks for VESA graphic driver.Runs thru preliminary screens and crashes at game start."Cannot render?"Cant get DOS32A to work..."cannot find paths error".help?
Reply 1 of 2, by eL_PuSHeR
I've got an idea that may work.
Make an ISO image of the cd-rom using UltraISO or WinISO.
Edit image by replacing dos4gw with DOS32A (simply rename dos32a.exe to dos4gw.exe to match names if not embedded).
Also you may need to replace univesa/univbe with something else if used.
After that, burn the modified image again to cd (rewritable) or mount it directly (image uncompressed into a folder) under DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
